标题: [google面试题]Describe a technique to identify a \"leader\" among a group of 10 identical servers that are all connected to every other server. [打印本页] 作者: 邢城 时间: 2013-7-30 17:24 标题: [google面试题]Describe a technique to identify a \"leader\" among a group of 10 identical servers that are all connected to every other server. There are no prior distinguishing characteristics of any of them and the same program to identify the leader startsrunning on all of them at the same time.After ananswer is given,ask how much network traffic it requires and,if "ties" are possible,ask how you can break ties.作者: 孙宏雷 时间: 2013-7-30 17:43
Good Answer:Have each server wait a random amount of time and then say "I'mit."The "I'mit" announcement is time‐stamped,and the computer that time‐stamped itsannouncement first i selected the leader.This approach requires sending out 9messages.If there is a tie,the computers can repeat the procedure.
