标题: [java interview]What if the static modifier is removed from the signature of the main method? [打印本页] 作者: 王萍 时间: 2013-8-16 13:08 标题: [java interview]What if the static modifier is removed from the signature of the main method? 作者: 李天一 时间: 2013-8-16 14:25
Program compiles. But at run time throws an error "NoSuchMethodError".
