标题: Infolytica软件中的RIM Design如何安装? [打印本页] 作者: 王维平 时间: 2013-4-11 10:55 标题: Infolytica软件中的RIM Design如何安装? 作者: 马晓荷 时间: 2013-6-8 10:36
Software RequirementsThe MathWorks MATLAB 7.2(R2006a 64-bit) orhigher The MathWorks Simulink 6.4(R2006a 64-bit) orhigher MagNet 6.25 (or higher) MagNet Plug-in for Simulinklicense for MagNet Actuator RSM Plug-in forSimulink 32-bit2.2·InstallationInstructionsdownloadIMPORTANT: If MagNet is running, close the applicationbefore proceeding. To installActuator RSM Plug-in for Simulink 2.2 32-bit, please follow all three steps:1.Locate the ARPlink22x86.exefile you downloaded from the Infolytica web site, www.infolytica.com. 2.Double-click the file.The Actuator RSM Plug-in for Simulink 2.2 32-bit Setup Program is initiated. 3.Follow the instructions givenby the Setup program. Upgrade InstructionsWhen upgrading from a previous version of Actuator RSM Plug-infor Simulink, simply follow the installation instructions above, the previousversion will be uninstalled automatically.Software RequirementsThe MathWorks MATLAB 7.2(R2006a 32-bit) orhigher The MathWorks Simulink 6.4(R2006a 32-bit) orhigher MagNet 7.1 (or higher) Actuator RSM Plug-in forSimulink license for MagNet Actuator RSM Plug-in forSimulink 64-bit2.2·InstallationInstructionsdownloadIMPORTANT: If MagNet is running, close the applicationbefore proceeding. To installActuator RSM Plug-in for Simulink 2.2 64-bit, please follow all three steps:1.Locate the ARPlink22x64.exefile you downloaded from the Infolytica web site, www.infolytica.com. 2.Double-click the file.The Actuator RSM Plug-in for Simulink 2.2 64-bit Setup Program is initiated. 3.Follow the instructions givenby the Setup program. Upgrade InstructionsWhen upgrading from a previous version of Actuator RSM Plug-infor Simulink, simply follow the installation instructions above, the previousversion will be uninstalled automatically.
