标题: 在Infolytica中如何使用parameter manager? [打印本页]
作者: 马斌    时间: 2013-4-11 11:08
作者: 马晓荷    时间: 2013-6-8 11:30
The Modeling Toolbox extension can be used to  list non-default system parameter settings, i.e. all the system parameters that have been explicitly changed by the user (image below)easily define and set user parametersset system parameters  for several objects at once[img][/img]Modeling Toolbox extension
