! transformer for 31500kVA/35kV/400V, developed by Ou
/FILNAME,Single
!Part 1: Initializing the parameter of geometry and properties.
Pi=3.1415926
Ri=94E-03 !Radius of iron core ;
G1=10E-03 !Gap between core and inner HV winding;
G2=5E-03 !Gap between LV and HV;
G3=5.5E-03 !Gap between winding and yoke;
Hhv=460E-03 !Height of HV winding;
Hlv=420E-03 !Height of LV winding;
Hi=Max(Hlv,Hhv)+2*G3
Whv=(12*2.6+11*5)*1E-03 !Width of inner HV winding;
Wlv=(3+5)*1E-03 !Width of LV winding;
Wt=450E-03 !Length between two core center lines;
Nlv=24 !Half turns of LV winding;
Slv=3*16E-06 !Area of core conductor about LV;
Flv=(Nlv*Slv)/(2*Wlv*Hlv) !Fill factor abou LV;
Shv=5.31E-06 !Areas of core conductor about HV;
Nhv=12*175 !Turns of HV winding;
Fhv=(Nhv*Shv)/(2*Whv*Hhv) !Fill factor abou HV;
T=T+CON
C=C+1
OUTRES,ALL,1
SOLVE
*END
*DO,I,1,81
*USE,LOAD
*ENDDO
FINISH
出现警告,是BFE命令用错了吧
作者: 孙海浪 时间: 2014-5-5 12:56
有一个问题,你用的53单元建模,那么肯定是二维模型了,那为什么BFE,ALL,JS,,I加载了x方向的电流?二维分析只能加载z方向电流啊For Lab = JS and STLOC = 1, VAL1, VAL2 and VAL3 are the X, Y, and Z components of current density (in the element coordinate system), and VAL4 is the phase angle.
