标题: OASIS快速启动指南(英文) [打印本页] 作者: 李苏克 时间: 2017-10-12 15:32 标题: OASIS快速启动指南(英文) Installing the Software
To install the OASIS software on the machine you want it to run on, start by running the installer.
During the installation, you will have the option to modify the install directory and any file associations used by OASIS. The installation process should be straight forward, and may take several minutes. OASIS快速启动指南(英文).pdf(938.65 KB, 下载次数: 18)
