[力学]ANSYS Mechanical
贾浩翰
2014-5-26 19:27
[img][/img]在做ANSYS随机振动谱分析时 当做到这一步在GUI界面中选择Main Menu>Solution>Load Step Opts>Spectrum>
SD>Calc Controls命令时 出现以下错误*** ERROR *** CP = 361.345 TIME= 17:11:11 Subscript range error. Parameter _ZC is dimensioned as 3, but location 4 is being requested *** ERROR *** CP = 361.423 TIME= 17:11:22 No data exists for dimensioned parameter _ZC with subscript 4. *** ERROR *** CP = 361.439 TIME= 17:11:24 The above error occurred processing field= _ZC(_Z1) Line= *SET,_z3,(_z3+1). *** ERROR *** CP = 361.735 TIME= 17:11:41 Subscript range error. Parameter _ZC is dimensioned as 3, but location 4 is being requested *** ERROR *** CP = 361.782 TIME= 17:11:50 No data exists for dimensioned parameter _ZC with subscript 4. *** ERROR *** SUPPRESSED MESSAGE CP = 361.798 TIME= 17:11:51 The above error occurred processing field= _ZC(_Z2) Line= *SET,_z3,(_z3+1). 求解怎么解决[img][/img]
