标题: 在Ansys中,遇到警告:After NUMMRG,ALL, node 84 (and possibly others) is associated with more than one solid model entity. Future commands which depend on the node to solid model connectivity (meshing, mesh clearing, solid BC transfer, etc.) may not operate prop [打印本页]
作者: 王鹏    时间: 2013-5-10 15:13
作者: 陈荣莲    时间: 2013-5-10 15:17
上面这个警告是提醒你:节点84同时属于号几个实体,在之后的操作中,如果操作到这个节点将有可能不能正确执行。
