标题: 在程序中利用API函数如何打开和关闭光驱门? [打印本页]
作者: 徐欣    时间: 2013-7-2 13:21
作者: 淡写轻描    时间: 2013-7-2 13:25
*API函数声明如下rivate Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As Long, ByVal hwndCallback As Long) As Long注释:调用时的代码如下Dim Ret As LongDim RetStr As String注释:打开光驱门Ret = mciSendString("set CDAudio door open", RetStr, 0, 0)注释:关闭光驱门Ret = mciSendString("set CDAudio door closed", RetStr, 0, 0)
