• 154025 - No conducting path was found between coil terminals (perhaps because no terminal faces or coil components were found in the material mesh). This can happen when two coil terminals belonging to different coils are in contact, in which case the workaround obviously consists of leaving an insulated gap between the terminals so that they are no longer in electrical contact. Another reason might be that the coil component is non-manifold.
共 1 个关于本帖的回复 最后回复于 2013-5-3 17:59
