启动并行计算时,总提示:You can press CTRL+C to stop the startup process!Unable to open the HKEY_LOCAL_MACHINESOFTWAREIntelMPISMPDprocess26908 registry key, error 5, 拒绝访问。Unable to open the HKEY_LOCAL_MACHINESOFTWAREIntelMPISMPDprocess13340 registry key, error 5, 拒绝访问。Unable to open the HKEY_LOCAL_MACHINESOFTWAREIntelMPISMPDprocess15792 registry key, error 5, 拒绝访问。。。。。。。不知是什么原因?要怎样修改? |
共 1 个关于本帖的回复 最后回复于 2014-4-5 10:01
