当我第一次运行 m文件成功后,第二次再运行时出现如下提示:Caught "std::exception" Exception message is:Message Catalog MATLAB:FileIO was not loaded from the file. Please check file location, format or contents这个时候也无法打开其它的m文件,该m文件需要处理400个文件,是不是因为处理文件过多?请高手看看是怎么回事,多谢!!
be more specific.1. if you load less than 400 , does it crash ?2. does it crash if you running other m file.3. version of your matlab4. how big is your ram.5. did you remember to close file, clear variables after one file is processed .6. check your memory comsumption during working process. when does it crush, how much memory you are used.
共 6 个关于本帖的回复 最后回复于 2014-5-8 17:08
