% Specify the waveform.hwav = phased.LinearFMWaveform('PulseWidth',1e-4,'PRF',5e3,... 'SampleRate',1e6,'OutputFormat','Pulses','NumPulses',1,... 'SweepBandwidth',1e5);w = getMatchedFilter(hwav);% Create a matched filter with no spectrum weighting, and a% matched filter that uses a Taylor window for spectrum% weighting.hmf = phased.MatchedFilter('Coefficients',w);hmf_taylor = phased.MatchedFilter('Coefficients',w,... 'SpectrumWindow','Taylor');% Create the signal and add noise.sig = step(hwav);rng(17)x = sig+0.5*(randn(length(sig),1)+1j*randn(length(sig),1));% Filter the noisy signal separately with each of the filters.y = step(hmf,x);y_taylor = step(hmf_taylor,x);% Plot the real parts of the waveform and noisy signal.t = linspace(0,numel(sig)/hwav.SampleRate,... hwav.SampleRate/hwav.PRF);subplot(2,1,1);plot(t,real(sig)); title('Input Signal');xlim([0 max(t)]); grid onylabel('Amplitude');subplot(2,1,2);plot(t,real(x)); title('Input Signal + Noise');xlim([0 max(t)]); grid onxlabel('Seconds'); ylabel('Amplitude');% Plot the magnitudes of the two matched filter outputs.figure;plot(t,abs(y),'b--');title('Matched Filter Output');xlim([0 max(t)]); grid onhold on;plot(t,abs(y_taylor),'r-');ylabel('Magnitude'); xlabel('Seconds');legend('No Spectrum Weighting','Taylor Window');hold off;这是你给我的答案,我把它截出来了,还有个问题,如果我想改噪声的信噪比,要怎么改啊 |
共 6 个关于本帖的回复 最后回复于 2014-5-8 17:19
