哪位大侠有LTE最新工具箱?官方信息:http://www.mathworks.cn/products/lte-system/?s_eid=PEP_5783 LTE System ToolboxLTE系统工具箱Simulate physical layer of LTE and LTE-Advanced wireless communications systems.对LTE和LTE-Advanced 无线通信系统的物理层进行仿真。LTE System Toolbox™ provides standard-compliant functions and tools for the design, simulation, and verification of LTE and LTE-Advanced communications systems. The system toolbox accelerates LTE algorithm and physical layer (PHY) development, supports golden reference verification and conformance testing, and enables test waveform generation. With the system toolbox, you can configure, simulate, measure, and analyze end-to-end communications links. You can also create and reuse a conformance test bench to verify that your designs, prototypes, and implementations comply with the LTE standard.LTE系统工具箱为LTE和LTE-Advanced通信系统的设计、仿真和验证提供标准兼容的函数和工具。该系统工具箱加速LTE算法和物理层(PHY)的开发,支持黄金参考验证和一致性测试,以及能够生成测试波形。通过该系统工具箱,您可以配置、模拟、测量和分析end-to-end通信连接。您也能够创建和重建测试平台以验证您的设计、原型、和实现都遵守LTE标准。 |
共 3 个关于本帖的回复 最后回复于 2015-11-1 07:43
