***ERROR: The nodes in the Abaqus/Viewer node set "ErrNodeRotNodeNoRotInert" have no rotary inertia about more than one axis associated with them and some rotational degrees of freedom at the nodes are not constrained. Either rotary inertia must be defined or all of the rotational degrees of freedom must be constrained. See the message file for more detailed information. |
共 0 个关于本帖的回复 最后回复于 2013-5-29 14:39
