Solver OutputANSYS Multiphysics                                *------------------------------------------------------------------*|        ||   W E L C O M E   T O   T H E   A N S Y S (R)  P R O G R A M     ||        |*------------------------------------------------------------------*****************************************************************                  ANSYS 14.5 LEGAL NOTICES                   *****************************************************************                                                             ** Copyright 2012 SAS IP, Inc.  All rights reserved.           ** Unauthorized use, distribution or duplication is            ** prohibited.                                                 **                                                             ** Ansys is a registered trademark of ANSYS, Inc. or its       ** subsidiaries in the United States or other countries.       ** See the ANSYS, Inc. online documentation or the ANSYS, Inc. ** documentation CD or online help for the complete Legal      ** Notice.                                                     **                                                             *****************************************************************                                                             ** THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       ** INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      ** PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    ** The software products and documentation are furnished by    ** ANSYS, Inc. or its subsidiaries under a software license    ** agreement that contains provisions concerning               ** non-disclosure, copying, length and nature of use,          ** compliance with exporting laws, warranties, disclaimers,    ** limitations of liability, and remedies, and other           ** provisions.  The software products and documentation may be ** used, disclosed, transferred, or copied only in accordance  ** with the terms and conditions of that software license      ** agreement.                                                  **                                                             ** ANSYS, Inc. is a UL registered                              ** ISO 9001:2008 company.                                      **                                                             *****************************************************************                                                             ** This product is subject to U.S. laws governing export and   ** re-export.                                                  **                                                             ** For U.S. Government users, except as specifically granted   ** by the ANSYS, Inc. software license agreement, the use,     ** duplication, or disclosure by the United States Government  ** is subject to restrictions stated in the ANSYS, Inc.        ** software license agreement and FAR 12.212 (for non-DOD      ** licenses).                                                  **                                                             ****************************************************************          *****  ANSYS COMMAND LINE ARGUMENTS  *****  BATCH MODE REQUESTED (-b)    = NOLIST  INPUT FILE COPY MODE (-c)    = COPY     2 PARALLEL CPUS REQUESTED  START-UP FILE MODE           = NOREAD  STOP FILE MODE               = NOREAD00694185          VERSION=WINDOWS x64     RELEASE= 14.5     UP20120918CURRENT JOBNAME=file  20:42:26  MAY 28, 2013 CP=      0.969PARAMETER _DS_PROGRESS =     999.0000000    /INPUT FILE= ds.dat  LINE=       0DO NOT WRITE ELEMENT RESULTS INTO DATABASE*GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  20.7072222    TITLE= Lev--Magnetostatic (A5)                                                       SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR  TYPE=STRI  DIMENSIONS=      248        1        1PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\_ProjectScratch\Scr230A\SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR  TYPE=STRI  DIMENSIONS=      248        1        1PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\Lev_files\dp0\SYS\MECH\SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR  TYPE=STRI  DIMENSIONS=      248        1        1PARAMETER _WB_USERFILES_DIR(1) = C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\Lev_files\user_files\--- Data in consistent MKS units.MKS UNITS SPECIFIED FOR INTERNAL      LENGTH        (l)  = METER (M)  MASS          (M)  = KILOGRAM (KG)  TIME          (t)  = SECOND (SEC)  TEMPERATURE   (T)  = CELSIUS (C)  TOFFSET            = 273.0  CHARGE        (Q)  = COULOMB  FORCE         (f)  = NEWTON (N) (KG-M/SEC2)  HEAT               = JOULE (N-M)  PRESSURE           = PASCAL (NEWTON/M**2)  ENERGY        (W)  = JOULE (N-M)  POWER         (P)  = WATT (N-M/SEC)  CURRENT       (i)  = AMPERE (COULOMBS/SEC)  CAPACITANCE   (C)  = FARAD  INDUCTANCE    (L)  = HENRY  MAGNETIC FLUX      = WEBER  RESISTANCE    (R)  = OHM  ELECTRIC POTENTIAL = VOLTINPUT  UNITS ARE ALSO SET TO MKS 1***** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE 14.5     *****ANSYS Multiphysics                                00694185          VERSION=WINDOWS x64   20:42:26  MAY 28, 2013 CP=      1.016Lev--Magnetostatic (A5)        ***** ANSYS ANALYSIS DEFINITION (PREP7) **************** Nodes for the whole assembly ********************** Elements for Body 1 "Rotor:1" ********************** Elements for Body 2 "levitation_core:1" ********************** Elements for Body 3 "levitation_coil_half:1" ********************** Elements for Body 4 "levitation_coil_half:2" ********************** Elements for Body 5 "Solid" ********************** Send User Defined Coordinate System(s) ********************** Set Reference Temperature ********************** Send Materials ********************** Send Named Selection as Node Component ********************** Set KEYOP for Solid Conductors ********************** Create FluxPar ********************** Create Coil Current ********************** Create Coil Current **************** ROUTINE COMPLETED *****  CP =         3.047--- Number of total nodes = 210679--- Number of contact elements = 0--- Number of spring elements = 0--- Number of bearing elements = 0--- Number of solid elements = 136592--- Number of total elements = 136592*GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  20.7075000    *****************************************************************************************************    SOLUTION       *****************************************************************************************************************  ANSYS SOLUTION ROUTINE  *****WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL    FOR ALL APPLICABLE ENTITIES*********************************************************************** SOLVE FOR LS 1 ****************SPECIFIED BODY FORCE JS   FOR ALL PICKED ELEMENTS AT STARTING LOCATION      2IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI162                    SPECIFIED BODY FORCE JS   FOR ALL PICKED ELEMENTS AT STARTING LOCATION      2IS SET ACCORDING TO TABLE PARAMETER = _LOADVARI230                    USE AUTOMATIC TIME STEPPING THIS LOAD STEPUSE       1 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL  DEGREES OF FREEDOMFOR AUTOMATIC TIME STEPPING:   USE     10 SUBSTEPS AS A MAXIMUM   USE      1 SUBSTEPS AS A MINIMUMTIME=  1.0000    ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE   FOR ALL APPLICABLE ENTITIESWRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF LAST   FOR ALL APPLICABLE ENTITIESCONVERGENCE ON CSG  BASED ON THE NORM OF THE N-R LOAD   WITH A TOLERANCE OF 0.5000E-02 AND A MINIMUM REFERENCE VALUE OF 0.1000E-05   USING THE L2 NORM (CHECK THE SRSS VALUE)*GET  ANSINTER_  FROM  ACTI  ITEM=INT        VALUE=  0.00000000    *IF  ANSINTER_                         ( =   0.00000     )  NE        0                                 ( =   0.00000     )  THEN    *ENDIF*****  ANSYS SOLVE    COMMAND  ******** TREE GAUGING FOR EDGE ELEMENTS ****** ERROR ***                           CP =       4.328   TIME= 20:42:28*** GAUGE command aborted ***                                           NUMBER OF WARNING MESSAGES ENCOUNTERED=          0NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****+--------------------- A N S Y S   S T A T I S T I C S ------------------------+Release: 14.5       Build: UP20120918   Platform: WINDOWS x64 Date Run: 05/28/2013   Time: 20:42Windows Process ID:         4968Processor Model:        Intel(R) Core(TM) i5-3330S CPU @ 2.70GHzCompiler: Intel(R) FORTRAN Compiler Version 11.1.0  (Build: 20100414)          Microsoft(R) Visual C/C++ Compiler Version 15.0  (Build: 30729)          Intel(R) Math Kernel Library Version 10.3.3 Product Build 20110314Total number of cores available    :    4Number of physical cores available :    4Number of cores requested          :    2 (Shared Memory Parallel)GPU Acceleration: Not RequestedJob Name: fileWorking Directory: C:\Users\Lei\Dropbox\MIT\Research\Analysis\Ansys\Lev\_ProjectScratch\Scr230ATotal CPU time for main thread                    :        3.6 secondsTotal CPU time summed for all threads             :        4.3 secondsElapsed time spent pre-processing model (/PREP7)  :        1.6 secondsElapsed time spent solution - preprocessing       :        0.0 secondsElapsed time spent computing solution             :        0.0 secondsElapsed time spent solution - postprocessing      :        0.0 secondsElapsed time spent post-processing model (/POST1) :        0.0 secondsMaximum total memory used                         :      363.0 MBMaximum total memory allocated                    :     1088.0 MBMaximum total memory available                    :          8 GB+------------------ E N D   A N S Y S   S T A T I S T I C S -------------------+*---------------------------------------------------------------------------*|        ||                            ANSYS RUN COMPLETED                            ||        ||---------------------------------------------------------------------------||        ||            Release 14.5           UP20120918         WINDOWS x64          ||        ||---------------------------------------------------------------------------||        || Database Requested(-db)   512 MB    Scratch Memory Requested       512 MB || Maximum Database Used     131 MB    Maximum Scratch Memory Used    232 MB ||        ||---------------------------------------------------------------------------||        ||        CP Time      (sec) =          4.328       Time  =  20:42:28        ||        Elapsed Time (sec) =          5.000       Date  =  05/28/2013      ||        |*---------------------------------------------------------------------------*
共 0 个关于本帖的回复 最后回复于 2013-5-31 13:10
