在做气动声学模块的时候,运行icfd时报错,用caasource和dft  On domain FiniteDomain.9.linear.2.0.0.#{FiniteDomain} all acoustic nodes (24729/24729) have been found in CFD structure.  --------------  ... done ( Localization process for acoustic nodes of domain FiniteDomain.9.linear.2.0.0.#{FiniteDomain} )  Localisation using the following projection parameters : gap tolerances (-0.001,0.001), plane tolerance 0.05, neighbouring dofs 2  ---- WARNING ----  Localisation method [LOCATE_PER_SURFACE] (with PLANE_TOL 0.05, GAP_TOL 0.001) report from process 0  (with point octree acceleration):  0 points (out of 1434) are localised, 1434 ( 100 % ) remains not found  -----------------  ... done ( Localisation using the following projection parameters : gap tolerances (-0.001,0.001), plane tolerance 0.05, neighbouring dofs 2 )  ---- CAUTION ----  During the localisation procedure, 100.00 percent of points could not be located.另外,因为显示的是定位问题,我用另外的加载背景流,mean cfd flow那部分试过,运行icfd是没有问题的,云图显示也是正常的。
共 1 个关于本帖的回复 最后回复于 2014-4-18 09:38
张虎 新来的 发表于 2014-4-18 09:38:55 | 只看该作者
你用interface的吗?计算前先用projection命令检查一下映射质量。参考Actran培训算例。
