·Curvature RefinementMinimum Element Size (CRMES) Can be used to set a lower bound thresholdto avoid over-discretization of a curved model entity This prevents the default CRR from effectivelydecreasing the MESbelow the CRMESon curved component faces Can be set at the model level Can be set at the local component volume,surface (3D only) and edge (3D only) levels
共 1 个关于本帖的回复 最后回复于 2013-6-8 10:30
