启动之前我先打开 license manager,确保了下面三个都是running;ANSYS, Inc. License Manager status:  Licensing Interconnect: running  Licensing Interconnect Monitor: running  FLEXlm: running然而,在启动icem cfd的时候就不能启动,出现如下提示:ICEM CFD 14.0Error: Failover feature 'ANSYS CFX-5 Anymodule' specified in license preferences is not available.Request name acfx_anymodule does not exist in the licensing pool.System clock has been set back.Feature:  acfx_anymoduleLicense path:  1055@PC-20121008PRXE;FLEXnet Licensing error:-88,309For further information, refer to the FLEXnet Licensing documentation,available at "www.acresso.com".ICEM CFD 14.0 Initialization Error:  failed to get ansys license 10019: return code 1, Failover feature 'ANSYS CFX-5 Anymodule' specified in license preferences is not available.Request name acfx_anymodule does not exist in the licensing pool.System clock has been set back.Feature:  acfx_anymoduleLicense path:  1055@PC-20121008PRXE;FLEXnet Licensing error:-88,309For further information, refer to the FLEXnet Licensing documentation,available at "www.acresso.com".You cannot use this function because a valid license for the mesh editor was not found.  Please make sure your license server is running and that you have a valid and available FEATURE or INCREMENT line for "aienv", "aimed", or "med".  If you are an academic user with a valid academic key, please verify that the "User's License Preferences" are set to "Use Academic Licenses".我自己尝试过如下的方法都没能成功:方法一:a.卸载ansys 14.0主程序和license manager(确保卸载干净了,清除了注册表,然后重启,)b.重新安装ansys 14.0主程序和license manager;c.ansys icem cfd启动出现如上问题;方法二:重新安装license,也出现如上问题;我之前用的是win 7 32bit sp1,安装ansys 14.0没一点问题;运行也好好的;但是同一个安装包为啥在win xp系统下就会出现问题呢?是不是xp系统下还需要设置环境变量什么的?敬请高手帮忙!
共 5 个关于本帖的回复 最后回复于 2014-4-29 10:12
枫舞纷飞 新来的 发表于 2014-4-25 21:07:14 | 只看该作者
cmd下 ipconfig/all 确保这里第一个mac不是无线网卡的mac并且与license的一致,如果数目与网络适配器那个窗口不一致,可能是部分网卡被隐藏了。找出来禁用。
贺昌城 新来的 发表于 2014-4-23 17:58:34 | 只看该作者
网关了就OK了
刘灿培 新来的 发表于 2014-4-23 17:59:38 | 只看该作者
我在安装和使用的时候都把网络禁用了,但是还是出现此类问题。
张洁 认证专家 发表于 2014-4-24 15:05:43 | 只看该作者
首先还是要说的,就是license的问题,你这个是没处理好!再者,系统兼容性是否需要考虑下呢?可以的话,试试换个系统,或者在别的xp电脑上安装试试
刘灿培 新来的 发表于 2014-4-29 10:12:52 | 只看该作者
我换了台电脑就好了,真奇怪
