应用workbench计算时,求解器显示的求解错误Error如下图所示,请问是怎么回事啊?还有提示的说参看troubleshooting section,请问在Help的哪里找啊?
内容是
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
共 2 个关于本帖的回复 最后回复于 2014-4-24 10:02
