workbench做完静力分析想进行实验,但需要知道最大主应力的方向来贴应变片。如何在workbench里输出或者看最大主应力的方向?
共 3 个关于本帖的回复 最后回复于 2014-7-17 17:35
秦舒浩 新来的 发表于 2014-7-17 14:42:59 | 只看该作者
坐等答案! 我也想知道!
刘国栋 新来的 发表于 2014-7-17 16:32:59 | 只看该作者
我也想知道
李立新 新来的 发表于 2014-7-17 17:35:52 | 只看该作者
Stress 下面有一个vector principal,好像可以显示最大主应力的方向。下面是help文件的解释,大家看看。我觉得这个就是。大家在workbench再试试。欢迎讨论啊!A Vector Principals plot provides a three-dimensional display of the relative size of the principal quantities (stresses or elastic strains), and the directions along which they occur. Positive principals point outwards and negative ones inwards.Plots of Vector Principals help depict the directions that experience the greatest amount of normal stress or elastic strain at any point in the body in response to the loading condition. The locus of directions of maximum principal stresses, for example, suggests paths of maximum load transfer throughout a body.Request a Vector Principals plot in the same way that you would request any other result. Scoping is also possible. Numerical data for these plots can be obtained by exporting the result values to an .XLS file. These files have 6 fields. The first three correspond to the maximum, middle, and minimum principal quantities (stresses or elastic strains). The last three correspond to the Mechanical APDL application Euler angle sequence (CLOCAL command in the ANSYS environment) required to produce a coordinate system whose X, Y and Z-axis are the directions of maximum, middle and minimum principal quantities, respectively. This Euler angle sequence is ThetaXY, ThetaYZ, and ThetaZX and orients the principal coordinate system relative to the global system. These results can be viewed using the Graphics button, so that you can use the Vector Display toolbar.
