MotorSolve5.10最新版本已经下载完成
64版本:
http://pan.baidu.com/s/1i3vQq4t
32版本:
http://yunpan.cn/cdjZ45bRD3LrD  访问密码 ba3c
相对motorsolve5.01版本做出的改进,英语介绍如下:
下面是中文汉化包
http://pan.baidu.com/s/1i3lcC89
These are the improvements:
- There have been significant solutionspeed-ups, most apparent in larger and more complex geometries, in all theMotorSolve modules. In benchmark tests performed at Infolytica, solutionspeed-ups of up to a factor of 60 times have been observed.
- Sizing and skew options have beenadded to the DCM module.
- A quick analysis method has been addedto the DCM module. This new method is called the "current-driven"analysis method.
- The user can now control the number ofadvance angles for the non-linear FEA solutions in the PWM analysis,significantly speeding up solutions.
- The VHDL export for BDC (brushless DCmodule) now supports both the linear and non-linear options and takes iron lossinto account. The VHDL export for IM (induction motor module) now takes ironloss into account.
And, there is now a new VHDL export forSRM (switched reluctance module). There have been similar improvements to theexport to Simulink option. Note that the Simulink Plug-in for MotorSolve moduleis also modified to support these improvements. This module will be availableshortly after the release of MotorSolve itself.
- A new file export option has beenadded to export to the SimScape format.
- Two new rotor templates have beenadded.
- Improvements have been made to thebreadloaf template parameters in the BDC module.
- The new version of MotorSolve will beavailable as a 32-bit and a 64-bit release. Up to now, MotorSolve has beenavailable only as a 32-bit release. However, as I mentioned to you in myearlier communications, future versions of MotorSolve will be available only asa 64-bit release. In effect, MotorSolve 5.1 provides a transition period andyou should take this opportunity to encourage all users to start using the64-bit release. Obviously, there are major advantages using the 64-bit release,in both the memory and speed of execution.
More details about the changes toMotorSolve will be available with the release. Please do not hesitate tocontact me if you have any questions.
收藏收藏1 分享分享 分享淘帖 支持支持 反对反对
共 11 个关于本帖的回复 最后回复于 2020-2-24 08:05
tbh550477890 新来的 发表于 2015-6-25 09:34:50 | 只看该作者
楼主给力,好东西,学习一下
范勇 版主 发表于 2015-6-25 20:40:32 | 只看该作者
这些都是改善:
- There have been significant solution speed-ups, most apparent in larger and more complex geometries, in all the MotorSolve modules. In benchmark tests performed at Infolytica, solution speed-ups of up to a factor of 60 times have been observed.
-有显著的求解速度,UPS,更大和更复杂的几何形状,最明显的,在所有的motorsolve模块。在基准测试进行了Infolytica,60倍液速度UPS已被观察到。
上浆和斜选择了DCM模块。
一个快速的分析方法已被添加到DCM模块。这种新方法被称为“电流驱动”的分析方法。
-用户现在可以控制在PWM分析的非线性有限元解的个数时的角度,大大加快解决方案。
- The VHDL export for BDC (brushless DCmodule) now supports both the linear and non-linear options and takes iron loss into account. The VHDL export for IM (induction motor module) now takes ironloss into account.
-出口(无刷直流模块的VHDL BDC)现在支持的线性与非线性选项,以铁损耗的考虑。IM VHDL出口(感应电机模块)现在需要铁缺乏考虑。
而且,现在有一个新的出口forsrm VHDL(开关磁阻模块)。已经有类似的改善,出口控制选项。请注意,SIMULINK插件为motorsolve模块进行改进以支持这些改进。该模块将motorsolve本身释放后被availableshortly。
一个新的文件导出选项增加出口的Simscape格式。
两个新的转子模板了。
- Improvements have been made to the bread-load template parameters in the BDC module.
-改进了面包加载模板参数在BDC模块。
- motorsolve新版本将可以作为一个32位和64位版本。到目前为止,motorsolve越来越激烈只作为一个32位版本。然而,当我提到你在myearlier通信,motorsolve的未来版本将仅为一个64位版本。实际上,motorsolve 5.1提供了一个过渡期,你应该借此机会鼓励所有用户开始使用64位版本。显然有很大的优势,使用64位版本,在记忆和执行速度。
More details about the changes to MotorSolve will be available with the release. Please do not hesitate tocontact me if you have any questions.
更多的细节变化motorsolve可释放。请不要犹豫与我联系如果您有任何问题。
范勇 版主 发表于 2015-6-25 20:41:29 | 只看该作者
百度翻译的,将就看吧.
Yestin 给力!发布下应用的情况吧,哈哈  详情 回复 发表于 2015-6-26 00:46
Yestin 九品主簿 发表于 2015-6-26 00:46:44 | 只看该作者
范勇 发表于 2015-6-25 20:41
百度翻译的,将就看吧.
给力!发布下应用的情况吧,哈哈
范勇 版主 发表于 2015-6-26 10:10:19 | 只看该作者
准备弄一个录屏软件录制一个视频来分享
刘健 新来的 发表于 2015-7-19 21:34:29 | 只看该作者
版主辛苦了!
列兵一号 新来的 发表于 2015-12-22 19:45:15 | 只看该作者
真心感谢啊,开始学习
9#
guygw1001 新来的 发表于 2017-2-10 15:45:23 | 只看该作者
进不了云盘,可否把32版的发我邮箱975587887@qq.com.谢谢!
10#
赤那棍 新来的 发表于 2017-2-21 11:06:52 | 只看该作者
guygw1001 发表于 2017-2-10 15:45
进不了云盘,可否把32版的发我邮箱.谢谢!
朋友 后面找到资源了没
