Q:
       ---- INFO ----
       Modified integration in component acoustic 1 has the value  0
        ---- FATAL ----
        The flow seems to be supersonic on some places.  It is advised that you check your input file.  Those values can be modified by setting the command line argument to a value between 0.9 and 1. The supersonic values higher than (cut_sos times the local s-o-s) will be cut to this value.
A:
          FTP上培训资料,海基自备的morhing声类比案例中,部分流场流速是超音速。在计算时需要输入命令将超音速流转换为亚音速计算。
          例如输入 -m 2000 --cutsos 0.99
          即将超音速流转换为0.99马赫数 --cutsos : allows to replace the supersonic values of the mean flow by a valueequal to the provided ratio times the speed of sound。
共 0 个关于本帖的回复 最后回复于 2015-7-15 13:30
