Installing the Software
To install the OASIS software on the machine you want it to run on,start by running the installer. During the installation, you will have the option to modify the install directory and any file associations used by OASIS. The installation process should be straight forward,and may take several minutes.
Figure 1 - Safenet interface http://localhost:1947
Installing a Trial License
If you obtained a trial license (V2C file) from our team, pleaselook to apply it to your installed copy of OASIS by following the  instructions below:
1. Navigate to http://localhost:1947 or  http://127.0.0.1:1947 on your browser
2. Click Update/Attach on the left menu
3. Click on Browse and provide the V2C file. Click Apply File afterwards
OASIS安装指南(英文).pdf (191.2 KB, 下载次数: 27)
共 1 个关于本帖的回复 最后回复于 2017-10-12 15:26
