已定义剪切模量仍报错要求定义,已粘贴inp文件*Material, name=explosive*Density1717.,*Elastic, type=SHEAR3.5e+09,*Eos, type=IGNITIONANDGROWTH, detonation energy=10200.7.781e+13, -5.031e+09, 0.8938, 11.3, 1.13。。。。。。。。。。。。。。。。。。。。。。。。。*Material, name=steel*Damage Initiation, criterion=JOHNSON COOK0.05, 3.44, -2.12, 0.002, 0.61, 1793., 300., 1.*Density7830.,*Elastic, type=SHEAR7.7e+10,。。。。。。。。。。。。。。。。。。errors:*elastic, type=shear must be used in conjunction with *eos to define the volumetric response of the material明明都已经定义过shear modulus,任然出现这种错误是什么原因啊? |
共 0 个关于本帖的回复 最后回复于 2013-5-20 14:25
